Home > Technical (L322) > Front Arm Ball Joint Removal, job done with pics |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
Spray, hammering, spray, chiselling, spray, impact chiselling, heat, spray, more hammering, spraying and chiselling. It is all about breaking a ring of corrosion between the ball joint body and the hub. Nightmare. Main problem is lack of clearance for swinging various hammers. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2nd Oct 2016 6:09pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If it's the one in the hub with the two ears and knocks out downwards then I heated mine up with a gas touch and hammered it from the top and inwards and also drove a chisel in under the ears where the bolts go through and it started to move. I did consider chopping of the ears and putting a socket or spacer over the threaded section and drawing it out using a nut on the thread but this may just pull the ball out of the joint..
2nd Oct 2016 10:22pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Heat
2nd Oct 2016 11:00pm |
If it's the one I'm thinking of that type of splitter won't do it, the other thing I did was get the jack supporting the hub next to it to give me something to hammer against.
3rd Oct 2016 3:11am |
I had to do a small mod on my splitter to open the throat a few MMs.
3rd Oct 2016 6:23am |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
Done it just got to get tracking done
3rd Oct 2016 6:12pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
Bit late to the party but next time try a proper penetrating oil. WD40 is pretty good but there are better, fundamentally WD40 was not designed as a penetration agent. Says something when the company behind WD40 make their own penetrating spray that isn't WD40.
3rd Oct 2016 7:12pm |
For the sake of a very small amount of never seize on the FF assembly line all this can be avoided, it could save millions of wasted man hours.
3rd Oct 2016 9:05pm |
WD 40 make a specialist fast release spray and Halfords do a shock and unlock spray which I have used both on large bolts on the RR.
4th Oct 2016 5:35am |
Went caveman on them
4th Oct 2016 6:40am |
Nice one, did you remember to tighten the inner arm pivot points with the weight on the car?
4th Oct 2016 7:16am |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
Is it not possible to drill out as much material as poss from the flat upward facing disc of the ball joint so creating room to smash the outer metal inwards away from the circular aperture of the hub carrier and lessen its grip? I'm about to tackle mine and it sounds a nightmare!! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
14th Aug 2019 10:34pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Probably not, there isn't a lot of room with the hub still on the car. |
15th Aug 2019 7:26pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 798 |
Holiday Chicken
18th Aug 2019 9:21am |
