![]() | Home > Technical (L322) > Heated wheel plug |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
does look like a power connector of some sort, the steering wheel heater would draw a fair amount of power, best thing to do is turn on heater and put a multimeter into the plug to test |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
If the flappy paddles are working then it's probably been rewired by using the heated steering wheel circuit which was the accepted way of doing the mod.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8402 ![]() ![]() ![]() |
Steering wheel heater draws very little current, runs on 0.75mm wires, 10amp fuse so it's probably around 100watts
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Thanks Pete. As I said in my original post,,the flaps are not connected. I will dig a bit deeper and break out the multimeter. No7 - 2003 V8 Vogue |
quick update. Managed to get round to testing a couple of things. I have power to the wheel ecu and Ive got a reading of 2.1 ohms for the element. Not sure what this should be though ? anyone have a figure for the element resistance ? No7 - 2003 V8 Vogue |
12volts at the maximum 10amp rating of the fuse (and it probably won't be anywhere near it) is 1.2 Ohms, so I guess it's probably goosed...
Such a shame if it is goosed. It's a real nice piano black off a 2010. Can't be any older than year or so. Will try powering it from another source to prove or disprove the element. No7 - 2003 V8 Vogue |
2.1ohms sounds about right for a heating element, which is about 75-100 watt depending on voltage (say nice round 2ohm for easy maths and @ 12v would be 6A and therefore 72W). |
Yep, your right, was doing it the wrong way... ooops.... |
