Home > Technical (L322) > Ancillary Belt Tensioner Help! |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
I've just replaced the water pump on my FF & came to tensioning the belt - I don't get it
20th Sep 2016 7:00pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8320 |
Think you have the belt on wrong, the tensioner is at full tension when at rest, you wind it back to fit the belt then release it and it tensions the belt... Pete
20th Sep 2016 10:32pm |
Ahh I see
20th Sep 2016 11:17pm |
So both bolts are undone and there is no tension- what am I doing wrong?? |
21st Sep 2016 9:05am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
21st Sep 2016 9:34am |
Thank you Ding, I've got that picture- I'm trying to figure out how the tensioner behaves and if I need to get a new one.
21st Sep 2016 9:49am |
Aaaar.. so you've undone it, you have to "recharge" it then, virtually impossible to describe... see these....
21st Sep 2016 2:59pm |
Those are the pages I've been working off buddy, I've undone everything but when I go to do the refit there is tons of play when I turn the 17mm anti clockwise - is the hydraulic spring meant to bounce back/provide resistance?
21st Sep 2016 3:39pm |
Loosen lock nut yellow 13mm (IIRC)
21st Sep 2016 4:15pm |
Got that - but I get to the limit of the groove for the blue bolt & it therefore doesn't tighten the belt? |
21st Sep 2016 4:31pm |
You have the belt routed wrong then, or it's the wrong belt.... Pete
21st Sep 2016 4:34pm |
So belt tensioned all good etc etc
23rd Sep 2016 7:04pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 |
Do a sniff test to see if there are exhaust gases in the coolant that will tell you if the head gasket has gone - you can buy the kit on fleabay or go to a local garage. I had a similar thing on a p38 and it was the heater matrix drawing air into the system hope this help a bit |
23rd Sep 2016 7:18pm |
