Home > Technical (L322) > Anyone got a gun?
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Anyone got a gun?
It's like the Forth bridge, I fix one fault and more appear so I'm thinking automotive euthanasia is the only solution.
Maybe not but I bet there's a few out there that feel the same way. Anyway this morning while bleeding the cooling system I got a few bongs on the dash, HDC, AIR SUS, TRANS FAIL SAFE etc and the car hadn't even moved.
So I did an IIDtool scan and came up with the following.
ABS-Brake Module
0x15 ABS ECU fault
EAS-Suspension
0x32 CAN bus Fault
ECM-Engine (ME7.2)
0x48C Electric thermostat circuit fault
0x4DD CAN bus missing node - ABS ECU
IP-Instrument Pack
0xF5 CAN bus fault - No ASC1 received from ABS ECU
0x8D Transmission Interface Bus fault
0xEE No ASC4 received from ABS ECU
0xBD EBV function fault received from ABS ECU
LCM-Light Control v11
0x57 Air suspension active/inactive
0x59 Transmission emergency program fault
SASM-Steering Angle
0x9 Incorrect CAN message
TBOX-Transfer Case
0x52E7 ASC1 lost from CAN (0x52E7)
0x52EC ASC2 lost from CAN (0x52EC)
TCM-Transmission
0x82 CAN bus ABS timeout: General fault
Ignoring the electrical thermostat fault I believe all of the faults relate to the ABS ECU anyone agree??
I've put a fresh battery on today and the alternator is putting out 14v - 14.2v
Please let me know your thoughts before I get grand Pappys shootin iron and shoot me a Range Rover Razz
Regards to all ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #405569 20th Sep 2016 3:16pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Simon,
You may have nudged/dislodged the ABS unit or got some moisture in the connector(it is upside down and so holds water!!). I found a tiny spec of green corrosion on one of the metal tongues in the connector which was enough for all the faults to appear. A simple clean with a toothbrush was sufficient to put everything back to normal.
Post #405571 20th Sep 2016 3:22pm
UK Marine
Hi,
Good idea I'll go and have a gander and see what I can see.
Cheers Thumbs Up ______________________________
Simon
Post #405573 20th Sep 2016 3:23pm
chawks
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
I have a Beretta shotgun.......but I've just cleaned it so you can't borrow it Laughing
Post #405605 20th Sep 2016 5:59pm
UK Marine
Aye go on, lift me up and drop me back down.... Big Cry ______________________________
Simon
Post #405617 20th Sep 2016 6:45pm
mzplcg
Surely, to shoot a Range Rover one should use a Purdey ?? Mr. Green
Post #405621 20th Sep 2016 7:05pm
UK Marine
Of course, my mistake.
One wouldn't want to look like a chav now would one Thumbs Up ______________________________
Simon
Post #405625 20th Sep 2016 7:11pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Gun for hire, maybe? Whistle 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #405644 20th Sep 2016 8:28pm
holidaychicken
Mine went cranky when I jacked up the front as the height sensors can drag crap into them either that or your battery is going flat
If I don't lock mine when I'm working on it the battery drains which can give you dozens of faults
Would be worth checking the thermostat heater electrical connection as that can corrode
Clear all faults using diagnostics and see what returns or steering lock to lock reset may help.
Bit more complicated than your Klepper...
Post #405653 20th Sep 2016 9:26pm
UK Marine
Hi,
I've just removed the thermostat for the 80 degree thermostat hack, so luckily I've just looked into the thermostat connector and it looks ok. You have to disconnect it that's why I'm getting the fault, other than that I'm thinking alternator because at best I'm getting 13.7 - 14.0v.
Regards ______________________________
Simon
Post #405656 20th Sep 2016 9:46pm
holidaychicken
Alternator should be around 14.8 v I believe, can you clear the faults with your diagnostics ?
I am about to do the 80 deg mod so don't know what effect it would have but I have read it doesn't cause any issues.
Normally multiple electrical faults are battery related and if you are sitting on idle bleeding the system then low battery or alternator would be a potential cause.
The ABS modules do fail causing multiple problems but if it will clear the faults and drive ok I would try using it keeping in mind your abs may not work. Mine would try and apply the HDC brakes until it faulted out and I just kept clearing and driving and it healed itself eventually
Have a gen up on X5 ABS module as there is a lot of information on them online
Post #405668 21st Sep 2016 12:11am
Digger7820
United Kingdom 2002 Range Rover Vogue Td6 Rimini Red
Box of Swan vester should work ok Whistle Big Cry Range Rover vogue Td6
Land Rover Defender TD5
Grand Jeep Cherokee
Discovery 300tdi
Discovery 200tdi
Series lll short wheel base
Super 7 kit car
AC Cobra (still got)
Post #405692 21st Sep 2016 8:31am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
I have the same issue on mine at the moment.
However, every time I try to check or clear the faults I get the HDC warning on the dash and the IID tool freezes up too so I need to go back to the start and try again. Big Cry
Had a new ABS module in earlier this year so hoping that's not on the blink again!
Apologies for thread hijack!
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #405709 21st Sep 2016 10:10am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
My wife keeps threatening to take ours up onto Salisbury Plain and let the Artillery at Larkhill Barracks have a pop at it!!
Post #405710 21st Sep 2016 10:13am
UK Marine
Hi Deranged,
You didn't hijack don't worry but you may have saved me an alternator.
Did the new ABS module sort out the problems because it's odd, every time I look to see if there are any faults with the IIDtool it throws up ABS, HDC and TRANS FAIL SAFE faults on the dash that weren't there before I started scanning and I can't clear them no matter what. It's odd..
But if an ABS module will sort it then that's what I'll go for because I'm not driving the Range Rover at the moment but am working on it and in and out of most of the day so the 13.7v I'm getting might just be the battery trying to get back up to spec..
Simon
Post #405805 21st Sep 2016 7:46pm
