![]() | Home > Technical (L322) > Anyone got a gun? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
It's like the Forth bridge, I fix one fault and more appear so I'm thinking automotive euthanasia is the only solution.
Hi,
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 308 ![]() ![]() ![]() |
I have a Beretta shotgun.......but I've just cleaned it so you can't borrow it |
Aye go on, lift me up and drop me back down.... |
Surely, to shoot a Range Rover one should use a Purdey ?? |
Of course, my mistake.
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Gun for hire, maybe? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Mine went cranky when I jacked up the front as the height sensors can drag crap into them either that or your battery is going flat
Hi,
Alternator should be around 14.8 v I believe, can you clear the faults with your diagnostics ?
Digger7820 Member Since: 04 Jan 2016 Location: Brigg Posts: 28 ![]() ![]() ![]() |
Box of Swan vester should work ok |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
I have the same issue on mine at the moment.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
My wife keeps threatening to take ours up onto Salisbury Plain and let the Artillery at Larkhill Barracks have a pop at it!! |
Hi Deranged,
