Home > Maintenance & Mods (L322) > Engine oil cooler issues .
fisha
Less than a week until its MOT, and having just serviced it with nice new oil, plugs and filters, came back to find the driveway pooled with oil. ( nothing out the norm with a land rover ).
I figured it would be that I hadn't quite tightened the oil filter right, but on inspection found that the oil was coming off of the cooler pipes running between the cooler and the pump.
I stripped the pipe off and cleaned it up and found the connector part of the hose full of grit / grime. Looked at the tube on the cooler and it had corroded quite badly. So much so that its corroded a hole in the pipe just before it meets the hose connector area.
Anyone else seen similar? Its as though grit, dust and grim has fallen into the spaces of the connector from general use, then with the salt etc etc has bored its way through. I don't think any of the grit has got into the oil as what what drained was clean, and the pressure of the oil at the pipe would have pushed muck out, rather than suck it in.
Sigh! Big Cry Laughing V8 or else ...
Post #405652 20th Sep 2016 9:25pm
fisha
Right, Can anyone tell me for definite the circuit of the oil cooling? ON the supercharged, there is an oil cooler radiator in the front wing, and a heat exchanger on the other side that exchanges heat with the coolant circuit. Does anyone know is they run in parallel ...
or in series ....
reason I ask is that the heat exchanged is fubarred at the moment, and I'm planning on disconnecting and plugging its oil lines so that all the oil goes just to the radiator part .... like this ....
but it matters if the coolers run in parallel or series on how I plug / re-connect it together. This is only a temp fix to keep the car running and will not be used for any heavy loads. V8 or else ...
Post #405718 21st Sep 2016 11:23am
fisha
I'll answer my own question about this ... its parallel. Blocked off the pipes as illustrated, and the oil cooler radiator gets warm during a drive. V8 or else ...
Post #405785 21st Sep 2016 5:50pm
