Home > In Car Electronics (L322) > Where is the front fuse box located in 2010 SC |
Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187 |
Open the lower glove box, and on the left side of the open glove box is a guide/stop, push it towards to the right and lower the glove box, behind it is a panel with a cover, two tabs hold it closed Dave
17th Jul 2016 5:30am |
bruzer Member Since: 16 Nov 2015 Location: Seattle, WA Posts: 44 |
Thanks! Any idea where/how I can safely ground a wire in or around the glove box/fuse box area? |
7th Sep 2016 6:20am |
my post on fitting my dash cam might help.
7th Sep 2016 8:23am |
HA! That's the same dashcam I'm trying to install. Is that bolt easy to get to? I remember quickly looking in there and couldn't find a screw/bolt that was easy to unscrew and screw |
7th Sep 2016 10:15am |
Once you have the cover off, its top right, the one with the blue sleeve, bear in mind mines right hand drive
7th Sep 2016 10:46am |
How did you test or verify that a fuse slot is either permanent live/always on/batt or powered on with key/acc? |
19th Sep 2016 1:26am |
No disrespect, but judging by the questions i think it would be safer if you go an auto electrician to install your dash cam mate Dave
20th Sep 2016 7:20am |
I understand and appreciate your honesty, but I'm a lifelong tinkerer - this challenge is part of the fun. I think this is more of the case where I have the skill set, but misplaced a tool.
20th Sep 2016 4:50pm |
