![]() | Home > Technical (L322) > Zf 5hp24 input shim |
RRPhil of course, he just started his own company specialized in your box !! MY 2010 5.0 SC Galway green and sand interior!!
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 ![]() ![]() ![]() |
Always assuming he has one.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1452 ![]() ![]() |
http://www.fullfatrr.com/forum/topic38676.html?highlight=5hp24 2021 D350 Fifty Edition - Carpathian Grey
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
I'll have to double-check in the morning but I generally have 1.8, 2.0, 2.2 & 2.4mm shims in stock. They're ridiculously expensive though (£12.30 +VAT)
Not sure yet.
As expected the output play feels non existant, measuring as well as i can as it slightly short of spec but i can not really pull hard enough or press hard enough so i am confident it is in spec.
Just checked and I have 4-off 2.0mm, 2-off 2.2mm and 3-off 2.4mm in stock at the moment.
I missed that last question.
You are confusing me with references to the ‘035’ transmission. The ‘035’ model of the 5HP24 was fitted to the 4.8 litre Alpina B10 & Roadster. I think that yours is a Range Rover fitted with the 4.6 litre engine, so you’ve converted a ‘034’ transmission to fit in a ‘032’ casing, is that correct?
Sigh, good job i did not claim to be an expert.....
