Home > Technical (L322) > Zf 5hp24 input shim |
RRPhil of course, he just started his own company specialized in your box !! MY 2010 5.0 SC Galway green and sand interior!!
19th Sep 2016 4:51pm |
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 |
Always assuming he has one.
19th Sep 2016 4:57pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1385 |
http://www.fullfatrr.com/forum/topic38676.html?highlight=5hp24 2017 4.4 SDV8 Autobiography
19th Sep 2016 5:12pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
I'll have to double-check in the morning but I generally have 1.8, 2.0, 2.2 & 2.4mm shims in stock. They're ridiculously expensive though (£12.30 +VAT)
19th Sep 2016 11:25pm |
Not sure yet.
20th Sep 2016 5:53am |
As expected the output play feels non existant, measuring as well as i can as it slightly short of spec but i can not really pull hard enough or press hard enough so i am confident it is in spec.
20th Sep 2016 9:31am |
Just checked and I have 4-off 2.0mm, 2-off 2.2mm and 3-off 2.4mm in stock at the moment.
20th Sep 2016 10:05am |
I missed that last question.
23rd Jan 2017 9:28am |
You are confusing me with references to the ‘035’ transmission. The ‘035’ model of the 5HP24 was fitted to the 4.8 litre Alpina B10 & Roadster. I think that yours is a Range Rover fitted with the 4.6 litre engine, so you’ve converted a ‘034’ transmission to fit in a ‘032’ casing, is that correct?
24th Jan 2017 9:48am |
Sigh, good job i did not claim to be an expert.....
24th Jan 2017 11:14am |
