![]() | Home > Maintenance & Mods (L322) > Oil Change |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
If the plate you are mentioning is to the left of the engine, looking forward, with 4 x 13mm bolts, then it doesn't need to come off. The drain plug is on the right rear of the sump pan on the TD6. Can be removed without taking off plates.
Welsh Walrus Jones Member Since: 10 Oct 2015 Location: Mountain Ash Posts: 18 ![]() ![]() ![]() |
Thanks for that and the service guide.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Yep, on a TD6 of that age there should be no need to remove anything to get at the sump plug. 17mm IIRC.
36mm for the oil filter cap. |
That's great, thanks.
