Home > Maintenance & Mods (L322) > Oil Change
Welsh Walrus Jones
Wales 2004 Range Rover Vogue Td6 Adriatic Blue
Oil Change
Hello All,
Trust well.
Have a very important topic to mention. Can anyone attach a photo of the front underneath of a 2004 Vogue? Mine starts with the ribbed boarding followed by a metal plate with 13mm nuts on underneath the engine.
Not sure whether this plate needs to come off to get at the sump plug as the bolts seem well torqued up.
Thanks for your help.
By the way, spoke to my friend who works for Castrol. He said the best oil they do is the Edge 0-30W but they quote the 5 - 40W for the year model etc..
Thanks for your time.
Post #404805 15th Sep 2016 9:39am
Weegie
If the plate you are mentioning is to the left of the engine, looking forward, with 4 x 13mm bolts, then it doesn't need to come off. The drain plug is on the right rear of the sump pan on the TD6. Can be removed without taking off plates.
Unless you have some other plates underneath? Very Happy
This might help:
http://workshop-manuals.com/landrover/l322...d6_engine/ John
GAP iiD BT
Post #404807 15th Sep 2016 10:01am
Welsh Walrus Jones
Thanks for that and the service guide.
Will keep you updated.
Cheers.
Post #404824 15th Sep 2016 11:51am
Yep, on a TD6 of that age there should be no need to remove anything to get at the sump plug. 17mm IIRC.
You will need a big socket (34 or 36 mm I forget...) to undo the oil filter cover up top. .
Post #404887 15th Sep 2016 6:03pm
Weegie
36mm for the oil filter cap. Thumbs Up
Also, best to use a socket as the cap is plastic and can be easily chewed up if trying to use anything else. John
GAP iiD BT
Post #404889 15th Sep 2016 6:06pm
Welsh Walrus Jones
That's great, thanks.
All done now. Took two runs round the block to get the oil on the top mark of the dipstick.
Have to say can't notice any difference to the sound and running of the engine yet.
Also, doesn't it get dark now in the evenings, I was getting the candles out at 7.45pm!!! Plus, so warm as well, it's like the south of France over here at the moment.
All the best and thank you for the replies.
Post #404909 15th Sep 2016 7:14pm
