Home > Technical (L322) > Rough idle on 2002 Vogue 4.4 V8 with lpg conversion |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8219 |
Do some googling on those fault codes but I'm pretty sure that is your camshaft position sensor starting to fail... timing would give the fault you are getting... Pete
13th Sep 2016 5:06pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
I found the SHFT in a different menu and got readings from -14 + 18
13th Sep 2016 6:02pm |
Sorry Pete I was out and about gathering readings and didn't read that properly! So Meeknet gives a fairly thorough write up on replacing these? http://www.meeknet.co.uk/e31/BMW_E31_840ci...cement.htm |
13th Sep 2016 6:18pm |
It's unusual for them both to fault... maybe worth a bit of reading to see if it's an indication of something else failing.... maybe it is a vanos issue and they are out of alignment or something and the ECU thinks the sensors are faulty... the diagnostics works in a very basic way, it can't tell if the sensor has failed, it just knows it's getting the wrong reading from them, and that could be because of a number of issues... Try the BMW forums for answers... Pete
13th Sep 2016 7:08pm |
Thank you buddy
13th Sep 2016 7:36pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3156 |
Deleted post |
13th Sep 2016 7:41pm |
