![]() | Home > Maintenance & Mods (L322) > Rear lower arm bushes |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
OOPS sorry |
Thanks guys all sorted |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Nice. Clears things up nicely for me. |
Just a question but is it ok to reuse the bolts as I've been told most places recommend fitting new ones due to corrosion weakening them with age?! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
The bolts are torque angle bolts and theoretically should not be reused. Some have without any issue. For the $6 each it give me peace of mind. |
That's enough for me |
165Nm torque and another 90 degrees for the arm to subframe bolts. |
Thanks |
80 NM for nut on ball joints. |
Thanks Doc |
If you are talking about the arm to subframe bolts they are the same KYG000043. The bolts that hold the upper ball joint in are included with the new ball joint as are the nuts. |
Ah the ones I got have no bolts, they aren't genuine lr though |
I use Moog suspension parts when possible. Seem to last longer than OEM. I did notice that some manufacturers don't include the upper ball joint bolts. Dealers do like it when they can charge for every little thing. |
Don't think I'll get moog over here but good for any WJ bits I need in the future other than the usual silly shipping prices |
