Home > Maintenance & Mods (L322) > Rear lower arm bushes
Page 2 of 4 <1234>
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi kp, autofactors, site sponsor on here does a great blow up view on his website, with all part numbers listed. Thumbs Up
Post #402504 30th Aug 2016 5:38am
gregdav
OOPS sorry Embarassed advanced factors. Thumbs Up
Post #402510 30th Aug 2016 6:22am
Thanks guys all sorted Smile
Went with Island 4x4 as they offer genuine units for £130 each including delivery Smile
I decided full arms with bearings in would be cheaper in terms of time as while they are out I may be able to get the bottom hub bushes done as I think i have them in my small pile of parts in the garage so two jobs in one with my near bearing/bushing removal kit Smile
Plus it looks like I could probably flog the used ones onto the bay for £30 each and then someone else could remove the damaged bushes and replace them and save themselves some money come swap over time Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #402528 30th Aug 2016 8:52am
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Nice. Clears things up nicely for me.
Post #402581 30th Aug 2016 1:28pm
Just a question but is it ok to reuse the bolts as I've been told most places recommend fitting new ones due to corrosion weakening them with age?! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #403963 7th Sep 2016 10:16pm
doclees
The bolts are torque angle bolts and theoretically should not be reused. Some have without any issue. For the $6 each it give me peace of mind.
Post #403971 8th Sep 2016 12:31am
That's enough for me Smile will get some ordered then Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #404121 8th Sep 2016 10:13pm
doclees
165Nm torque and another 90 degrees for the arm to subframe bolts.
Post #404127 9th Sep 2016 4:17am
Thanks Smile
What about the hub side one? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #404259 9th Sep 2016 8:47pm
doclees
80 NM for nut on ball joints.
Post #404264 9th Sep 2016 9:28pm
Thanks Doc Smile
Trying to find the part numbers for the upper and lower bolts on the hub and the ones for the lower arm if anyone has them to hand Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #404412 11th Sep 2016 3:54pm
doclees
If you are talking about the arm to subframe bolts they are the same KYG000043. The bolts that hold the upper ball joint in are included with the new ball joint as are the nuts.
Post #404417 11th Sep 2016 4:59pm
Ah the ones I got have no bolts, they aren't genuine lr though Sad
Thanks for the ones to the subframe Smile
Just leaves the two on the hub Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #404424 11th Sep 2016 6:08pm
doclees
I use Moog suspension parts when possible. Seem to last longer than OEM. I did notice that some manufacturers don't include the upper ball joint bolts. Dealers do like it when they can charge for every little thing.
Post #404436 11th Sep 2016 7:30pm
Don't think I'll get moog over here but good for any WJ bits I need in the future other than the usual silly shipping prices Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #404440 11th Sep 2016 7:53pm
Page 2 of 4 <1234>
