Home > Maintenance & Mods (L322) > JET WASHING your FFRR - READ THIS *
Page 3 of 3 <123
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Mines bigger than yours. Shocked Shocked Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #403583 6th Sep 2016 7:42am
mzplcg
LOL, my Butt probably is, well according to SWMBO. Laughing
Jetwashing is all about pressure and flow rate though, and the more it can produce the wider the nozzle you can use to get the same result. Wider nozzle means more area covered. Feeding a large PW with a smaller one would limit the large machine to the flow rate of the small one.
One of the reasons I went over to a water butt was that our mains water delivery is low due to lead mains. Whenever someone flushed the bog it would starve the PW of supply and make it vibrate, i.e. the pump was cavitating. Using a water butt with a 3/4" hose instead of a 1/2" one cured that and gave it more delivery at the nozzle.
Post #403587 6th Sep 2016 8:09am
D34NO
United Kingdom 2003 Range Rover HSE Td6 Monte Carlo Blue
Currently living in military housing so not paying for water....no problem here! Cool
Post #403622 6th Sep 2016 10:29am
johnboyairey
Using a smaller one to boost a bigger one won't restrict it, it's the end nozzle that does the restricting, your smaller pump, will build a small amount of pressure, but feed in fine, the big pump, will boost the incoming pressure, and as long as there's a restriction, on the end lance, your spray will be better. You can see this if you hold it in the air, the tiny amount of water, that is being used.
Post #403627 6th Sep 2016 10:59am
Page 3 of 3 <123
