Home > Maintenance & Mods (L322) > Steering column wont go forward or backwards, water ingress?
tiddles1991
United Kingdom 2004 Range Rover Vogue Td6 Buckingham Blue
We had some heavy rain over the weekend and for some reason the rainwater has found its way through my car and started dripping from above my accelerator pedal.
At the same time my steering column has decided it will go up and down but not forward or backwards and when i get in the car it sounds like its trying and doesn't stop until i press it forward or backwards.
Anyone had any similar problems?
Post #403534 5th Sep 2016 9:24pm
Water leak will 99% of the time be from the windscreen coming away from the shell at both top corners...
Steering column failure is very common, either broken motor or mechanism, mostly this bit if it's the mechanism...
http://www.ebay.co.uk/itm/Range-Rover-L322...Sw5ZBWM861 Pete
Post #403566 5th Sep 2016 11:51pm
