Home > Technical (L322) > IID fault codes
Dave
IID fault codes
When i first got the IID tool i cleared all faults. The only two that are constant are Driver door mirror. Is there any way of seeing if the mirror heater works, i've felt it mirror with the back of my hand, when on, and even tried using my breath to
see if the mist disperses, or will i just have to wait for winter?
Second is Exhaust gas recirculation temperature sensor A - circuit high - is this bad and should i be worried?
Cheers
Model L322 - Range Rover 2012
Vehicle scanned on 5 Sep 2016 09:03:56
IIDControl 2.6.1 Android - IIDTool BT V3.0 B2185
DDM-Driver Door
• B1164-15 (2F) Right mirror heater output - General electrical failure - circuit short to battery or open
PCM-Engine TDV8
• P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high Dave
2012 Vogue Westminster 4.4
Post #403376 5th Sep 2016 8:38am
