Home > Maintenance & Mods (L322) > intercooler change on td6
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
this may have been covered before,but has anyone changed the intercooler on a ff td6 2005,i read somewere that you dont have to take the rad out ,you can slide it out through the nearside wheel arch ,is this true.mine is leaking at the drivers side bottom.
Post #220927 5th Nov 2013 2:19pm
frikkadel
South Africa
I would also like to know. mine is leaking oil on the right hand side
Post #402561 30th Aug 2016 11:54am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
An old thread, resurrected recently.
I have replaced a TD6 intercooler, but it was several years ago. It had many, many pinhole leaks and was spraying a fine mist of oil over everything. It's not the easiest of jobs, nor the most difficult. There is quite a lot to dismantle, then it just about squeezes through the wheel arch.
This thread gives good information - including, thanks to Martin, the relevant pages from RAVE, which gives a detailed account of how to remove and replace it. http://www.fullfatrr.com/forum/topic20343.html
Steve Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #403068 2nd Sep 2016 4:38pm
frikkadel
South Africa
Thanks, now that its summer here, i think i will spend a day getting this sorted.
Will let you know how it goes.
Post #403161 3rd Sep 2016 11:31am
cowman
yes did mine and you can get it through the wheel arch
Post #403246 4th Sep 2016 9:31am
frikkadel
South Africa
Does one still have to pull the front of the car apart or can the whole job be done through the wheel arch
Post #403373 5th Sep 2016 8:14am
cowman
you have to take the bumper off and the fan and cowling + washer bottle.
Post #403441 5th Sep 2016 2:45pm
frikkadel
South Africa
Ok, pulling that stuff doesnt sound too bad, thing is when you pull it all and its got holes in then you have to go look for one without going to the stealers.
Post #403588 6th Sep 2016 8:23am
V8Simon
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
Adding some info to an old thread for anyone taking this job on. I've just done this and it took a full day and a half although first time I've done anything to my FF so it was a learning session also.
The info in the RAVE updates in the post highlighted (again here http://www.fullfatrr.com/forum/topic20343.html) is crucial to getting the job done. If I did it again, I'd take the viscous fan off first and pull the plastic fan surround up and out to give some space to work. You need two 32mm spanners to get the fan off and some muscle without the official LR tools as reaching in and holding one on the waterpump and the other on the fan and giving it some pressure I found hard.
Most is straight forward and is just a matter of unscrewing a mixture of 8mm, 10mm & 13mm screws, bolts and captive fastenings. Apart from the 16mm for the front crash bar, thats all you need really.
Have a method for keeping all the fastening with the right bits, especially when it comes to all the plastic stuff that comes off the front.
Check the metal ends on the intercooler hoses fit on to the intercooler before fitting. One of mine went on no problems but found the one down by screen wash would not go on so I've attached the hose direct to the intercooler outlet and will investigate another time.
Getting the intercooler out the wheel arch is difficult to say the least, I took mine out the offside to save removing the screen wash bottle and with full lock on, it worked but its tight. Taking the old one out isn't too bad as its, well old but getting the new shiny one in without damaging is more fun. Don't underestimate the joy when it clicks in to place.
Allow some time to get the bumper, plastic bits on the front and the wheel arch liners all aligned for the fasteners to go in and don't tighten any until your happy everything is in and lined up. 2004 Vogue SE TD6
(Also a LR 90 V8 & RRS, just because)
Post #597412 14th Jun 2021 7:25am
