![]() | Home > Technical (L322) > 4.4 v8 hard to start when warm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8555 ![]() ![]() ![]() |
Camshaft or crankshaft sensors can start to fail when hot, fuel pump can wear out and give lower pressure when hot, coils can break down...
mattyp Member Since: 30 Jul 2016 Location: Clacton On Sea, Essex Posts: 101 ![]() ![]() ![]() |
What one would you recommend to buy |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
pete is right, you cant go wrong buying a diganostoic device, like the IID tool. and if you get the bluetooth one, it gives you some very impressive functions, on say you ipad or phone. or the non bluetooth one that uses the pixels display on the dash. i have a different one the 'allcomms' which i use with a laptop. i think people agree the iid tool is best.
The car starts on the button from cold and when warm the engine turns over for ages then it starts. I had the codes read and this is what it showed
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
DTC 98: Tank vent solenoid might be an interesting one to explore.
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
I have the same problem and have yet to find it.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 760 ![]() ![]() |
Might be worth checking that it's not the LPG causing the problem before you blame your car, I've seen it happen on a few LPG cars where an injector starts to leak gas when the engine isn't running - this gives symptoms similar to "flooding" when restarting.
Well that didn't work ![]() Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
I found my warm starting problem was caused by the fuel filter
Mattstevenson2005
