Home > Wheels & Tyres > Rotating Tyres |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
I have noticed that the dealer seems to rotate mine when it's in for its service. So every year or so.
24th Aug 2016 5:08pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
I never rotate tyres, just means you have to buy four all at once instead of two at a time... Pete
24th Aug 2016 5:09pm |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 |
I find if I don't rotate the tyres the car doesn't move anywhere?? 😆 |
27th Aug 2016 11:51am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
I prefer to buy all 4 together as I like to have matching tyres - all the same & evenly worn.
27th Aug 2016 12:10pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Indeed, I rotate mine every time I drive anywhere Got - 2017 SDV8 Autobiography in Loire Blue
27th Aug 2016 12:20pm |
Experience of doing this has shown me that moving tyres around, especially side to side gives untold issues with noise, straight line steering and generally less than good feeling.
28th Aug 2016 8:44am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
i agree with Dom..when i managed a tyre centre i recommend to customers to keep the tyre on the corner it was fitted due the the above reasons.. ... - .- -.
28th Aug 2016 9:10am |
I also agree with Dom (and Stan) as I also heard many stories about tyres changing location causing issues !!! MY 2010 5.0 SC Galway green and sand interior!!
28th Aug 2016 2:09pm |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
I have done a bit or research on this, it appears most major tyre manufacturers recommend tyre rotation. In respect to 4x4 vehicles this is to maintain tyre wear evenly to prevent transmission wind up.
31st Aug 2016 8:20am |
you now have some educated answers to help make your decision.. ... - .- -.
31st Aug 2016 8:34am |
To help even out wear. Hmmm, so they acknowledge that all 4 corners have a different wear pattern which is PRECISELY the reason to leave them where they are. Like I said before, front to rear have differing geometry. Side to side and you'll find the tyre rotating the other way so you have the tread feathering going the wrong way, to completely ruin straight line stability for you. A surefire way to upset the way a car drives and wear the tyres out prematurely. Oh wait, don't tyre places actually SELL tyres?
31st Aug 2016 9:34am |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Beware of rotating directional tyres or you could have rotation the wrong way and the tread pattern won't do what you think it should!
31st Aug 2016 10:58am |
good point Clive ... - .- -.
31st Aug 2016 11:12am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I have never understood why anyone would want to d*ck around with tyres on a two and a half ton car just put them on make sure your alignment is correct balance and pressures and change all 4 when they wear out - that way you will be making sure you have the safest set up - works for me |
31st Aug 2016 2:01pm |
