![]() | Home > In Car Electronics (L322) > Venture Cam Holster / Dock repairing latch mechanism |
StewD Member Since: 22 Apr 2016 Location: Glasgow Posts: 129 ![]() ![]() ![]() |
A quickly slung together how to guide for repairing the Venture Cam Dock latch mechanism.
Remove a few screws on the bottom section of the exposed dash
Remove kick panel scuff guard and footwell trim
Remove screw from here on underside of dash
Remove grommet from inside of dock
Remove another screw
Pull enclosure towards the rear of the car and out, but don't get carried away there are 2 cables to remove
Try not to shake the enclosure too much, the broken tab will hopefully be rattling about, it's very small. The enclosure handily has no holes for it to fall out of 👍 Find yourself a seat.... Remove the dock from the dash unit, just a few screws required. Here is where the tab should live....
Here's the tab
A spot of superglue, a steady hand and a pair of long nose pliers and hopefully you'll end up with this...
In true Haynes fashion reassembly is the reverse of disassembly... |
Thanks for this, great info.
You're welcome.... it's a team game |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Using a cut off beer mat is a lot less hassle! Previous cars:
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8521 ![]() ![]() ![]() |
Nice write up... |
TimperleyRR Member Since: 13 Aug 2016 Location: Manchester Posts: 50 ![]() ![]() ![]() |
Dear Stew D
Haylands.... they all seem to have a wedged beer mat piece holding them in.... mine did when I got it... 🙄 Current: Supercharged 06 FFRR in Java Black
Must admit I don't use. When I need to admire it, I just pull the dock down and scrabble about in the foot-well to retrieve the beer mat! |
