![]() | Home > Technical (L322) > TD6 ignition key would not turn |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
its the steering lock ecu , known issue and can be gotten around by drilling a small hole in the casing and lubricating the solenoid plunger - use silicone rather than wd40
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Does this happen enough that doing a drill and lube as a preventative a good practice? |
I wouldn't mess with it if its working correctly tbh |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
Many thanks dingg1. If it happens again we will give the steering wheel a good shake, before we embark on microsurgery 2011 Vogue TDV8 4.4
Scud it WILL happen again if its started already , putting a toggle switch acoss fuse 18 is also a remedy , the lubrication and hole drilling has worked for a while for me now and I think is the best option , other than stripping down the ecu and solenoid plunger , which may be the next option |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
theres something in the wiki re this, might help.. ... - .- -.
thats for key stuck in ignition
Stan, it may be worth putting this plus the link in the wiki 2011 Vogue TDV8 4.4
tiddles1991 Member Since: 10 Jul 2016 Location: Cleethorpes Posts: 32 ![]() ![]() ![]() |
I had the same issue, replaced my battery and it worked fine. |
