Home > Technical (L322) > TD6 ignition key would not turn
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
My son in law couldn't start his TD6 today because the key would not turn in the lock. I immediately suspected lo battery volts, but on checking these were 12.2v. We also confirmed that he had it in park. Managed to get the key to turn and the car to start by disconnecting the battery negative terminal for a while then reconnecting. Have left a 10 MM. spanner in the car in case we have to resort to this agin.
The Kay fob is the original and is 10 years old, and the car is not used much, so I suspected that might be the cause. We are now using his spare key and all seems ok at present.
Can anyone advise on the likely cause?
I put my IID BT toll on his car, but that is locked to my own VIn. Nevertheless it was able to read fault codes which included one for the immobiliser. I have cleared these faults and they have not recurred.
Any help on avoiding a recurrence would be appreciated 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #401960 25th Aug 2016 2:46pm
dingg1
its the steering lock ecu , known issue and can be gotten around by drilling a small hole in the casing and lubricating the solenoid plunger - use silicone rather than wd40
http://www.blackbox-solutions.com/photos/L322lock.pdf
Post #401961 25th Aug 2016 3:02pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Does this happen enough that doing a drill and lube as a preventative a good practice?
Post #401962 25th Aug 2016 3:25pm
dingg1
I wouldn't mess with it if its working correctly tbh
Post #401964 25th Aug 2016 3:27pm
scuddriver
Many thanks dingg1. If it happens again we will give the steering wheel a good shake, before we embark on microsurgery 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #401992 25th Aug 2016 7:48pm
dingg1
Scud it WILL happen again if its started already , putting a toggle switch acoss fuse 18 is also a remedy , the lubrication and hole drilling has worked for a while for me now and I think is the best option , other than stripping down the ecu and solenoid plunger , which may be the next option
Post #402002 25th Aug 2016 9:52pm
theres something in the wiki re this, might help.. ... - .- -.
Post #402004 25th Aug 2016 10:04pm
dingg1
thats for key stuck in ignition
not the same issue the op was having unless I missed something Wink
Post #402032 26th Aug 2016 7:58am
^ Thumbs Up ... - .- -.
Post #402041 26th Aug 2016 8:57am
scuddriver
Stan, it may be worth putting this plus the link in the wiki 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #402770 31st Aug 2016 4:03pm
tiddles1991
United Kingdom 2004 Range Rover Vogue Td6 Buckingham Blue
I had the same issue, replaced my battery and it worked fine.
Post #405295 18th Sep 2016 9:12pm
