Home > Technical (L322) > td6 gearbox
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
td6 gearbox
question on td6 gearbox in the mornings i first start ff put in drive press pedal and nothing for first 2 to 3 seconds is this normal Question its done it as long as ive had it even though ive had gearbox service .it runs fine rest of the day.
Post #401576 22nd Aug 2016 3:31pm
RRPhil
Issues that only occur when the transmission is cold are often linked to low fluid level. Maybe worth checking it.
Phil
Post #401580 22nd Aug 2016 3:42pm
hgbosch
South Africa
Re: td6 gearbox
Hi vmaxer
a full gearbox/TC flush with a new autobox filter will sort out your problem. Very Happy
As your rig will get on in miles, once you feel a slip in TC lockup under heavy acceleration in 5th gear, immediately take the rig to your friendly gearbox place and ask them to rebuild the TC and modify the gearbox oilpump and solenoid with the Sonnax kit.
http://www.sonnax.com/parts/4120-remanufactured-valve-body (GM-071 for L322 Td6)
Failure to do so will strand you with a destroyed TC and a FULL gearbox rebuild. Unfortunately got my t-shirt on that one.
Good luck
Post #401613 22nd Aug 2016 7:55pm
fil b
England 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Re: td6 gearbox
Post #402640 30th Aug 2016 5:36pm
hgbosch
South Africa
Hi fil b
When you say you press the pedal and nothing happens, then I deduct you mean the accelerator. This has nothing to do with the box but seems to me like an electronic issue.
Before going on a wild goose chase, fully charge the battery and see if that changes anything. If not then you need to hook it up to some serious diagnostic unit, either dealer or MSV-2. If the battery charge doesn't solve, you would most probably have to dive into canbus issues.
Hope this helps
Please give feedback once solved
Post #402649 30th Aug 2016 6:34pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Mine has done the same for years, reverse fine but only forward when warmed up or put into manual mode, will engage drive in auto after approx 10 secs, had gearbox services etc but live with it now Thumbs Up
Post #402674 30th Aug 2016 8:54pm
hgbosch
South Africa
Hi rosco
the situation that you describe points to a valve body issue. When my box went south I insisted that it be fitted with the Sonnax modifications, which cure 2 of the main causes of gearbox failure on the 5L40DE GM box:
1. Excessive bore wear on the oil pump solenoid housing.
2. Excessive bore wear on the valve body solenoid bores.
Here is the link
http://www.sonnax.com/parts?utf8=%E2%9C%93...mit=Filter
Not fixing your drive engage hesitation will most probably over time lead to the destruction of the TCC, as it is a pressure related issue.
Hope this helps
Post #402692 30th Aug 2016 10:16pm
Rosco
Thanks hgbosch, will look into it Thumbs Up (sorry to hijack OP)
Post #402714 31st Aug 2016 6:48am
vmaxer
g box
so cars been in to check oil lever and for them to sort problem out and guess wot Shocked Shocked Shocked the bloody thing didnt miss a beat they had it for 3days tried it every morning and every morning spot on Rolling Eyes mechanic said its probably the torque converter emptying over night or fluid is draining passed a seal over night but with it not happening on him he could,nt say then the wife piped up that its never happened on her Confused must be that the ff dos,nt like me Big Cry
Post #403918 7th Sep 2016 5:02pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I had that problem a while back. If the car was left standing overnight, in the morning after starting it wouldn't drive forward for a few seconds. I mentioned it to a gearbox specialist and he told me it sounded like the oil was draining back into the sump and needed a few seconds to circulate back into the box and build up pressure. I believe it is a faulty valve or seal (as mentioned in above post). I did have one embarrassing occasions when I was staying at a hotel with valet parking. He eventually turned up at reception in the morning saying he thought he had broken the car as he couldn't get it moving.
I ran the car like that for over a year. Eventually I had other gear box issues (probably not related) and changed the box. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #404750 14th Sep 2016 4:02pm
