Home > Technical (L322) > Chirping sound and chaffing when turning right.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
I have 2 different sounds from my 03 td6.
One is chirping on bumpy roads especially noticable while going on brakes.Likely coming from back.
I notice sometimes when i get out when the truck moves but i cant hear when i jog the truck.
The other is chaffing when turning right agressivly when truck leans over.Chaffing is not continious like a part of the whhel is touching when faster sound intervals are lesser time.
Thanks all
Post #401471 21st Aug 2016 3:36pm
Well done for having a TD6 in the USA Thumbs Up
I know you are from the USA but it is NOT a "truck" Smile
Sounds like your issues are mostly suspension, possibly dry joints or mountings. Spend a bit of time with something like WD40 squirting on all obvious joints, especially the wishbone inner joints at the rear.
Other possibilities may be loose/rusting brake disc covers front/rear, worn ARB bushes & mountings.
Thumbs Up .
Post #401482 21st Aug 2016 4:46pm
umitbat
Re: Chirping sound and chaffing when turning right.
Unnecessary quote removed
Not in usa;)
Interestingly when i pull the handbrake it squeakes from left side as i jog the car up down.
When the handbrake is down it does not.
While driving it occurs sometime-handbrake is down of course;)
Post #401935 25th Aug 2016 9:33am
