Home > Technical (L322) > Sat nav intermittent use.
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
Morning,
My sat Nav woes.
When t is dry my nav works fine- when it is wet is doesn't.
No water ingress by Nav as far as I can see - so suspecting GPS receiver is getting wet or wires corroded and stopping boot up - is that a possibility ?
Any other ideas ?
Ta muchly 2011 Range Rover Vogue SE
Post #401292 20th Aug 2016 10:26am
n1cktdv8
As you probably know the Sat Nav is stored in the rear side panel in the boot area. An area that's seen lots of wet issues over the years in RR's. LR did a warranty repair kit which was essentially a plastic sleeve for the inner area. Check that area thoroughly and see if water/moisture is getting in. I've seen a couple of examples where you can see rusted screws etc so that'd be my first thought. Is this where I put the car details and a bit about myself ?........
Post #401296 20th Aug 2016 10:39am
Busa1400
I have put a new boot seal on and the waterproof seal is in place and the area now has dust in so it is dry - just wondering if the feed in can cause an issue 2011 Range Rover Vogue SE
Post #401303 20th Aug 2016 11:17am
Weegie
The aerial on the roof? John
GAP iiD BT-Sold
Post #401305 20th Aug 2016 11:27am
Busa1400
Hello Sir, long time no speak - the bluetooth is fabulous by the way.
I'm thinking that aswell - the navunit is not booting up when wet and the next thing was be the roof aerial - I'll get that swapped out 2011 Range Rover Vogue SE
Post #401306 20th Aug 2016 11:29am
