Home > Technical (L322) > Sat nav intermittent use. |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
As you probably know the Sat Nav is stored in the rear side panel in the boot area. An area that's seen lots of wet issues over the years in RR's. LR did a warranty repair kit which was essentially a plastic sleeve for the inner area. Check that area thoroughly and see if water/moisture is getting in. I've seen a couple of examples where you can see rusted screws etc so that'd be my first thought. Is this where I put the car details and a bit about myself ?........ |
20th Aug 2016 10:39am |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 |
I have put a new boot seal on and the waterproof seal is in place and the area now has dust in so it is dry - just wondering if the feed in can cause an issue 2011 Range Rover Vogue SE |
20th Aug 2016 11:17am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3217 |
The aerial on the roof? John
20th Aug 2016 11:27am |
Hello Sir, long time no speak - the bluetooth is fabulous by the way.
20th Aug 2016 11:29am |
