![]() | Home > General > My cars at the dealers today. |
I take it you will be getting a refund for the sw upgrade then!? You pay for your car to be fixed - if they did not fix it you do not pay. D ![]() |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Its a nice thought, but I've never known a garage refund when issue turned out to be something else. However, I'm more ![]() The dealer I purchased the car from also confirmed today that they will pay for a new battery ![]() Cheers JustinP ![]() Gone - Range Rover Supercharged 2006 ![]() |
If they have said "you need this to fix it" and it doesnt fix it then it really is simple.
I hope to get a full refund for all the stuff I had done last week from Land Rover Warranty, but if that fails I will kick off to Marshals about the software update not fixing the problem. I really wish Guy Salmon in Sheffield where I bought the car from was closer, as they have treated my very well.
Marshals have agreed to refund the cost of the software upgrade on the grounds that it did not fix the stalling on startup problem. They have also fitted a new battery which Guy Salmon have agreed to pay for, so I'm just waiting for a couple of cheques to arrive in post and I'm happy bunny again.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Mine does this as well! I thought it was the Mass airflow sensor, so replaced it, but no change. As you say, a little revving takes care of it, though I would rather get a full fix! 2012 SDV8 Vogue SE |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
It is a joke really, i wish i could draw\design something wrong and then re-invoice the company to correct it.. ![]() |
The stalling on cold startup got worse, so its currently back at the dealers for a 3rd time to investigate and fix. I've uploaded a youtube video demonstrating the problem in the hope one of you may be able to suggest a fix. http://www.youtube.com/watch?v=_B0qx9jmb7E Cheers Justin ![]() Gone - Range Rover Supercharged 2006 ![]() |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
i know its a completely different kettle of fish but i had a little rover 25 doing the exact same thing that two previous garages failed to fix, after some diagnostics and a bit of head scratching it turned out to be the battery. it would wind over no problem every time giving the impression of a good strong battery but as soon as it started it would stop just like yours, a quick and inexpensive way to to eliminate the battery is to connect a battery booster pack to it and see if it still does the same thing. it cant hurt to give it a go. |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Could it be a fuel line leak.. not enough to let fuel run out but enough to allow air in.. I know it sounds odd but it can happen, thus allowing the main line to empty. You then have enough to fire up from an residual left in the injector rails. Once thats gone the pump needs to catch up.
iancollins Member Since: 17 Mar 2010 Location: milton keynes Posts: 264 ![]() ![]() ![]() |
i wonder how many times you will vist the dealer to get the problem fixed but then give up !!!!
My cold startup problem has been fixed |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Great news! Don't suppose you got the LTB number?
Sorry I don't, once I've confirmed its fixed for certain on the next frosty morning, i will email the dealer and ask. ![]() Gone - Range Rover Supercharged 2006 ![]() |
