Home > Technical (L322) > 07 RR Airbag module location. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
From memory Its under the carpet thats under the console |
14th Aug 2016 11:48pm |
jam220 Member Since: 08 Jun 2016 Location: Atlanta Posts: 31 |
thank you that was the only other place it could be. Please let me know when you are back from vacation I still want to order the headlight wires |
15th Aug 2016 12:59am |
I moved the carpet towards the front of the console I still don't see it. =.. the module is decent size cant really miss it but I don't see it |
15th Aug 2016 12:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
info should be in the WM... ... - .- -.
15th Aug 2016 12:38pm |
Work Manual (WM)? I dont have manual but i got some diagrams which shows its under the console i keep at it. Thank you |
15th Aug 2016 7:29pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8066 |
Just had a look in the WM (Workshop manual) all it says about it's location is...
15th Aug 2016 8:23pm |
thank you sir ill keep digging, I was trying to avoid taking out the console completely but seems ill have to do it. |
15th Aug 2016 10:33pm |
ok found it, three of the nuts that holds down the shift assembly is exposed is the 4th one have to be accessed through the bottom of the car? |
16th Aug 2016 3:53am |
UPDATE: Got it thank you all |
17th Aug 2016 3:49pm |
Pete
17th Aug 2016 5:22pm |
