Home > Maintenance & Mods (L322) > 2002 DRL on 2010 facelift?
Danwilderspin
It appears since doing the 2010 facelift that I have found you can't code drl on my age of ff. has anyone done a hard wired version?
Post #400602 15th Aug 2016 1:24pm
Danwilderspin
bump
Post #400722 16th Aug 2016 4:12pm
if you mean hard wire the little dot leds in the headlights then i dont recall anyone doing that.. ... - .- -.
Post #400730 16th Aug 2016 4:43pm
Danwilderspin
Stan did you just change that message as my email said something different - yes exactly that and some led fogs I put in - only WAy I can think of doing it it to run a relay with an ignition live trigger to send 12v to everything but not sure how Lcm would react to 12v on something it didn't send?
Post #400752 16th Aug 2016 8:23pm
yes i did change the post after i re-read your post..
the headlight leds are a bit of a waste of time as they arnt very bright in daylight, i have converted my fogs to drl's which is a better option.. ... - .- -.
Post #400754 16th Aug 2016 8:35pm
5 pin relay is the cheapest way to wire the twinkly LED’s to work as DRL’s...
Post #400778 16th Aug 2016 11:31pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I fitted DRLs into my headlights, after them being branded as Harry Potter scars I swapped them for a wigly line. Anyway, back to the point, Very cheap to get a dedicated DRL controller. These combine a relay and voltage sensing so they come on once the engine is running and go off 10 secs after engine off. Depending on local regs there is also a connection to the headlamp + feed which dims the DRLs when headlights are on.. Cheap as chips..http://www.ebay.co.uk/itm/LED-Daytime-Runn...SwGYVW8m8a 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #400783 17th Aug 2016 5:13am
Danwilderspin
so my question - if i get one of those eBay things - and T into the live going to the drl in the headlights all the lcm get upset that 12v are going to the lights and its not being sent from it (will i blow anything up?)
Post #401032 18th Aug 2016 5:26pm
wayneg
The unit connects to the battery + and senses when the voltage exceeds 13.7v, thats when the cars running and switches on the DRLs, stay away from the lcm and headlight + 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #401095 19th Aug 2016 2:23am
Danwilderspin
So would you disconnect the sidelights entirely and just wore them as drl so effective have the switch as headlight on and off? Only problem is that I would get bulb faults?
Post #401115 19th Aug 2016 9:42am
wayneg
I am a bit confused as to what you are trying to do. My understanding is you have swapped headlights with no DRL with Headlghts With DRL. If thats the case then I would have thought you only then need to connect the new drls via a relay of sorts. No idea if thats not the case. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #401124 19th Aug 2016 10:17am
Danwilderspin
Hi basically on the >10 I believe the sidelights are the drl so the leds in the rings - at the moment I have to turn sidelights on to use them. I think the easiest thing would be to somehow trigger the sidelight at the switch from ignition if that's possible?
Post #402038 26th Aug 2016 7:45am
i would take some wizardry to get two feeds going to the little leds in the headlights..
search 'hello halos' and see if you like that idea.. ... - .- -.
Post #402043 26th Aug 2016 8:00am
Danwilderspin
Right inadvertently resolved this - got an intravee todAy and I thought it was just an iPod adapter ... Oh no it's not you can chose to have drl and which lights individually you want - I have set my front fogs and halos and it's just the job I'm really chuffed! Also I have set it to Powerfold mirrors on lock and unfold on unlock. I the. Turned on something which was definately not an option at our age vehicle - triple turn activation if you catch the indicator it will indicate three times like newer vehicles! Finally I set the map to auto zoom in and out. It also has pdc display etc.
Not bad for what i thought was just an MP3 adapter - and that's good too - it puts the info on the cluster and the nav if you want which is great!
If you want one they are on offer until midnight £99 plus vat at toysinmycar.com highly recommended!
Post #402118 26th Aug 2016 4:26pm
RangeK1D
Canada 2004 Range Rover HSE 4.4 V8 Zambezi Silver
Hey Dan, did you post a video with the intrave on youtube by any chance? I Think I might have stumbled across it after looking up intrave ahaha. How is that system working? From what I understood so far, it is an ipod kit, but it also allows you to changing which lights come on? So if the vehicle is set into drive, you can choose to turn off the high beam acting as a DRL and use the LED Halo's as the DRL?
Btw I have a face-lifted 2004 --> 2010 Range Rover. Zambezi Silver Range Rover (2010 Autobiography Facelift)
Mercedes Benz GL450 4Matic (X164)
Mercedes Benz E500 4Matic (W211) (Sold)
Mercedes Benz 300SDL (W126)
Lexus LX470 (J100)
Audi A8L (D3 Chassis)
Post #420661 1st Jan 2017 9:20pm
