Home > General > What Did You Do In Your Full Fat Today |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Did oil change and changed the top pipe that goes into the egr with a silicon jobby.
16th Aug 2016 9:14pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
New AMK compressor installed, height has now levelled out, access mode is now much lower thankfully, diesel leak now also hopefully fixed after replacing water sensor at the base of the filter, now have a brand new filter top housing available as wasn't needed but came as one, thanks JLR! |
18th Aug 2016 1:34pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Spotted my mates ramp was empty so on it like a flash, oil dropped and filter replaced. Only 6 thous since it was last done but it can't do any harm. |
22nd Aug 2016 4:09pm |
Hmb Member Since: 12 Jun 2016 Location: Essex Posts: 90 |
Washed, polished, and waxed the sc. then took oldest clay shooting 2010 Overfinch 3.6 V8 FFRR gone yee haa
22nd Aug 2016 4:14pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Did almost 600 mile round trip , still can't crack the 20 MPG.
22nd Aug 2016 8:09pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2581 |
looked at it in a sad way as battery has gone! lasted 5 years so thats good |
22nd Aug 2016 8:26pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Oils and filters changed. Levels checked. 4 post lift makes all the difference. John
27th Aug 2016 8:36am |
abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93 |
Swore at it.
27th Aug 2016 10:24am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
New rear upper knuckle replaced , EGRs turned off and remapped with a Quantum tuning map. 48 more horses and 110 Nm torques NICE
27th Aug 2016 8:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
after ten days of non use i was apprehensive to whether mine would start or not......
28th Aug 2016 9:50am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Mt Baker National Forest, Washington State, USA. Monday.
31st Aug 2016 12:34am |
markyp Member Since: 04 Feb 2013 Location: essex Posts: 234 |
Just spent 2 hours cleaning and treating all the leather, gotta say its come up well 👍 2004 vogue
5th Sep 2016 12:58pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Replaced air compressor piston ring.
8th Sep 2016 6:05am |
Had the air con tested and re-gassed - €49. John
8th Sep 2016 2:05pm |
