Home > Maintenance & Mods (L322) > Help. Split inter cooler hose
33sport
2007 Range Rover Vogue TDV8 Stornoway Grey
Help anyone know of a temporary fix for the inter cooler hose, I have a small split 25mm in length, I am currently in the southern France, the nearest dealer is some 200 miles away!
Appreciate any advice.
Thanks in advance.
Post #400732 16th Aug 2016 4:53pm
Weegie
Duct tape? As per here: http://www.fullfatrr.com/forum/topic26723....=duct+tape
Where are you? John
GAP iiD BT
Post #400733 16th Aug 2016 5:09pm
you need to have this as your avatar John, Wink
Post #400734 16th Aug 2016 5:12pm
Weegie
Shocked John
GAP iiD BT
Post #400735 16th Aug 2016 5:21pm
dogsbody21g
United Kingdom 2009 Range Rover Vogue SE TDV8 Rimini Red
Cut out split section with hacksaw and 'splint' with a scrounged section of exhaust pipe and X2 jubilee clips. Brought me back from Calabria to Devon no problems and no reduced speed!
Post #400745 16th Aug 2016 7:10pm
That looks like a good tip
Pipe tape would be better - see this thread
Generally they are OK to drive with - if you floor it, you will get a ton of smoke and a warning, may go into shutdown mode, but turn off & restart and it should clear - so if there is a dealer en-route, you should be OK - assuming they have one in stock.
When do you come back ? Dan @ Duckworths can probably ship one to you
Post #400750 16th Aug 2016 7:50pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
That's what happened to us with the tin tent down Cornwall. No real loss of power, but blotted everyone out at the rear.
Fitted a new one from Truro Land Rover, luckily they had one in stock and all well and good.
Has a downside to mpg though, 19 mpg from Colne to campsite outside Redruth (400 miles).
On the return leg 22 mpg, same journey and about same speeds. (brimmed tank no consumption meter).
Had to clear an airflow fault as well.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #400751 16th Aug 2016 8:03pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Mine went last year when I was France. Dan at duckworths got a new one to me in 2 days whilst I was in France
Post #400768 16th Aug 2016 9:34pm
tape will work fine and dandy, duct tape, will be ok, the pipe repair tape is best though as it has some self amalgamating tape in the kit.
not sure that they have halfords in france... Rolling Eyes but find a brico depot for some duct tape and use that and it will get you home if you are gentle on the pedal. plenty of turns of tape and spread a good couple of inches from the hole in each direction to ensure a decent seal, the webbing the the tape will help stop it bursting.
oh and insulation/electrical tape doesnt work well. dont ask me how i know..... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #400897 17th Aug 2016 7:44pm
Weegie
Norauto is similar to Halfords. Any quincaillerie (hardware shop) or supermarket will have duct tape. John
GAP iiD BT
Post #400903 17th Aug 2016 7:52pm
33sport
thanks for the tips. I got new hoses direct from LR in Bordeaux and paid twice the uk price! But when needs must...
I have found that im still getting a fair bit of black smoke on kick down, will this clear itself now I have changed the hoses or do I have another problem?
Post #402198 27th Aug 2016 9:50am
Did you replace both hoses ?
Post #402215 27th Aug 2016 11:57am
33sport
yes I replaced both hoses, although the smoke is not as bad but still present on kick down. Sad
Post #402361 28th Aug 2016 8:03pm
Lurpak
England 2005 Range Rover HSE Td6 Stornoway Grey
I’ve ended up cleaning the inside of the split, and superglue, left over night and now 3-0 miles later still going? I really should get it fixed proper, that being said anybody know where the end goes at the bottom of the top hose on a tdv6?
Post #560001 2nd Jul 2020 7:36pm
