Home > Technical (L322) > Gremlins!
D34NO
United Kingdom 2003 Range Rover HSE Td6 Monte Carlo Blue
Gremlins!
While out driving tonight, I pulled up at a shop got out and my car wouldn't lock!! No matter what I done!! No buttons on my key fob done anything!! OK so I got back in and drove home, it started raining put the windscreen wipers on, 15mins later they just stopped, I tried all positions on the stick and still nothing would happen!! Drove home very carefully and pulled up, i done nothing other than put it into Park and put the handbrake on, thought I'd try the windscreen wipers again and they started working!!! Got out and the keyfob started working again!! Locked, unlocked no dramas!!!
Has anyone got any ideas???
Post #398895 2nd Aug 2016 7:55pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Could have been local security camera's or equipment interference with your fob, hasn't happened to me, but I have heard about it.
Post #398896 2nd Aug 2016 8:00pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I'd agree with gregdav on this one.
Not happened in my L322 but on my old P38 I saw people have issues all the time, then one day happened to me! Luckily I pushed it off the forecourt and all was good!
I'd keep an eye on it, or if anything else goes adrift check the battery and alternator!
Post #398899 2nd Aug 2016 8:11pm
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
Sounds lile the bcm is packing/playing up.
It controls remote locking and wipers and common to go wrong on the older models (on my phone can't see your model)
Post #398902 2nd Aug 2016 8:23pm
D34NO
My car is HSE 53 plate 3.0 td6. Will look into bcm then cheers.
Post #398986 3rd Aug 2016 12:30pm
Weegie
Did you sort out your hourly bongs? John
GAP iiD BT
Post #398987 3rd Aug 2016 12:35pm
D34NO
Ha ha yes I did cheers and it's awesome now!!!
Post #398993 3rd Aug 2016 1:26pm
Winkelried
Switzerland 2006 Range Rover Vogue 4.4 V8 Santorini Black
Hy,
I never had it happen to me in my L322, but the P38a was famous for that.
They changed the Frequency with the new Model its way better. But when the BeCM gets no clear signal it decides to do nothing (even worse when trying to unlock Sad )
I had it happen (P38a) near security networks, remote operated cranes, very big electro Motors and trafo stations. I then had to wait till the source was gone or push my car some meters away Censored
Greetings from Switzerland
Peter
Post #400515 14th Aug 2016 6:23pm
I'd second the BECM, the L322 is far better shielded than the old P38 against electrical interference and it wouldn't effect your wipers anyway...
Difficult to confirm it's the BECM as it's an intermittent fault... either wait till something else happens or just replace it...
Could see if any faults are logged which may give some help....
Thumbs Up Pete
Post #400516 14th Aug 2016 7:01pm
D34NO
My parking sensors have now gone tits up! The long beep and flashing light etc! Not sure if it's connected but a mate of mine reckons hes got a diagnostic machine so I'll get his off him and try and see what's happening! Thinking of it though this parking sensors issue has only played up since using my pressure washer on the wagon?? Poss cause???
Post #400647 15th Aug 2016 8:09pm
mzplcg
It can in theory damage sensors but I've never managed it and I have a Nixon (agricultural) jetwash.
Post #400650 15th Aug 2016 8:17pm
