Home > Maintenance & Mods (L405) > excessive brake pad wear on L405 |
How do you know the pads are down to 3mm (has a garage advised you to that effect or have you seen it for yourself)? |
13th Aug 2016 6:20am |
VF15 Member Since: 10 Aug 2016 Location: worcestershire Posts: 3 |
I had a puncture and they checked the pads. |
13th Aug 2016 10:09am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
I would check them myself, sounds like someone may be angling for business. Agueroooooooooo. 93-20
13th Aug 2016 10:42am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I was told by the main dealer that the fronts were fine but the rears had only a few months left on them. I think the rears might be binding. Car has done 21000 miles. |
14th Aug 2016 6:51am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
If you were down to 3mm the warning light would be on. |
14th Aug 2016 8:14am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2569 |
Adaptive cruise must be hard on brakes - following something using it is really irritating with brake lights constantly flashing away in situations where you'd just lift off without it on. |
14th Aug 2016 9:15am |
I've seen them for myself. Brake warning light is not on, I agree the cruise control is very annoying. I believe this is the reason for the pad wear. |
14th Aug 2016 11:06am |
Argyll Rover Member Since: 08 Aug 2016 Location: West Coast Posts: 2 |
Confusing!! I seriously considered two used SD8s both with rear pads replaced at 24k, but still plenty of meat left on the original fronts. Fronts "always wear out first" though not on the L405, so it seems. Pads do seem to be rather small. Is this a brake design flaw, LR? |
13th Dec 2016 6:15pm |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
30k miles on my 5.0SC and at last service I'm told the pads are at only 50% so I'm happy.
13th Dec 2016 8:13pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
I've had over 30k out of mine - and I also drive reasonably hard.
13th Dec 2016 8:46pm |
Aeroresh Member Since: 31 May 2008 Location: North Wales Posts: 137 |
45k on the original pads still so cant complain.
13th Dec 2016 10:00pm |
