Home > Technical (L322) > The old old (coolant) story....... |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
Hi All,
9th Aug 2016 9:00pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
I'd take the radiator out and test it for flow, if it looks old, replace it, it'll be clogged up at the bottom and cause transmission oil cooler problems too. Then replace the thermostat. Two straight-forward DIY jobs that won't blow the bank.
9th Aug 2016 10:45pm |
Hi,
10th Aug 2016 8:26am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2256 |
I haven't had any issues with my l322 but with the classic and the p38 I have had similar issues usually it is crud in the rad it blocks the rad but also moves and blocks in a different place also not sure if the 322 rads are the same internal design but in the p38 there were baffles that could and did come loose so for the sake of your sanity I would as has been said replace rad first good luck |
10th Aug 2016 9:14am |
Hi, yes I agree, just waiting for the fan removal tool and off it comes ______________________________
10th Aug 2016 11:53am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
I would replace the rad, water pump , expansion tank ( genuine part only is a must for this) and mod the thermostat to the lower temp. All fair easy stuff but worthwhile to keep on top of the coolant. V8 or else ... |
10th Aug 2016 7:16pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
And check that the tank has a 140kPa cap, not 200. Ron B. VK2OTC
10th Aug 2016 10:46pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I've had a few coolant problems, but mainly due to leaks. If you are not losing significant coolant, then half the battle is won.
10th Aug 2016 11:10pm |
Hi Guys and thank you all for your excellent advice, it's all been taken onboard.
11th Aug 2016 2:44pm |
That stuff is known as 'Harry Monk's sperminating high-protein cream'
11th Aug 2016 3:16pm |
11th Aug 2016 3:32pm |
Looks like it was put in to seal the radiator. So, maybe that explains its presence.
11th Aug 2016 3:59pm |
County Antrim, I've no idea. I live County Durham up by Newcastle upon Tyne, ha way the lads and all that.......... ______________________________
11th Aug 2016 7:04pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
I think you are thinking of the Irish Republic where, as I understand it, vehicle tax rates are very high. On the other hand County Antrim, being in Northern Ireland, is part of the United Kingdom with the same rates of tax as the rest of the UK. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
11th Aug 2016 7:22pm |
