Home > Technical (L322) > The old old (coolant) story.......
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi All,
Well as per the title really.
I bought what I thought was probably the cheapest 2003 l322 v8 in the country @ £2400. It had an over pressurising problem and if you've been following my other posts, a bit of a problem with the electronics - now solved yeah!!.
So now I've turned my attention to the cooling system. The problem reported by the previous owner (and I've learned not to trust what this guy has said if you've followed my previous posts) is that he bought it knowing it had a cooling problem, he bought it, drove it home some 5 miles, and the coolant expansion tank cap blew steam and coolant everywhere just as he was pulling up at home. He thought head gaskets and decided to offload it onto someone else - enter me.
I've had a block test that came back all clear so no head gasket faults. Now being new to l322 ownership but not to the Range Rover family I've followed the old tried and tested logical approaches to why the coolant seems not to flow around the engine, blocked radiator (might still be the problem as I haven't taken it off yet), faulty thermostat or a blockage in the coolant flow passages. As you are probably and painfully aware the logical approach to l322 ownership doesn't always apply.
I've looked at the entry's in this forum regarding the various coolant problems with this model and there are plenty, but I would like to gauge your views regarding the thermostat. You see I hooked up the IIDtool and read the live values for the coolant temp into the radiator and the temp coming out of the radiator because the top hose, as is always reported by forum posters, is rock hard and too hot to touch but the bottom hose is almost cold. So logically the flow is restricted ie the thermostat isn't opening. So I looked at the temps and going into the radiator it's 106 and coming out 25 so a massive difference and I for one don't think that the radiator is that effective.
So what do you think, could it be the thermostat or am I not waiting long enough for it to open, because it is only 106 and the thermostat is rated at 105 I believe. I've put in some coolant flush to loosen up anything that might be in there and I'll drain it over the next few days but what I did notice is that draining the radiator took a good 10 - 15 minutes and only got out 4 litres, so it could be blocked.
So back to the logical approach, replace the radiator, replace the thermostat, take a good look at the water pump but I did notice coolant moving into the expansion tank from the small bore overflow pipe. And as a side note I am getting warm air inside the car when I move the temps to highs.
But the logical approach is suspect, isn't it? Could it be an airlock? I don't want to blow steam out of the cap again..
After I put the coolant flush I took it out for 10 or so minutes to try and get it up to temperature but the needle didn't move much past cold and as I've said the top hose was, in my opinion, far too hot and far to hard, even though they do run hot and under pressure. Now I'm not averse to getting my hands dirty ( I have owned a few P38s 😇) but my head is starting to hurt and that can't be good...
Regards to all.. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #399857 9th Aug 2016 9:00pm
I'd take the radiator out and test it for flow, if it looks old, replace it, it'll be clogged up at the bottom and cause transmission oil cooler problems too. Then replace the thermostat. Two straight-forward DIY jobs that won't blow the bank.
If that doesn't sort it, move onto the water pump.... .
Post #399874 9th Aug 2016 10:45pm
UK Marine
Hi,
I'm just waiting for my viscous fan tool to turn up then I'll do as you suggest, it was just odd that the coolant ran out as a fast drop then a slow trickle, so I do think it's at least sludged up.
So I'm hoping that the coolant flush I've put in does a bit of good.
I'll keep everyone updated as it goes along as this seems to be a continuous problem for some if not most.
Regards to all. ______________________________
Simon
Post #399901 10th Aug 2016 8:26am
Sandyt
I haven't had any issues with my l322 but with the classic and the p38 I have had similar issues usually it is crud in the rad it blocks the rad but also moves and blocks in a different place also not sure if the 322 rads are the same internal design but in the p38 there were baffles that could and did come loose so for the sake of your sanity I would as has been said replace rad first good luck
Post #399907 10th Aug 2016 9:14am
UK Marine
Hi, yes I agree, just waiting for the fan removal tool and off it comes Very Happy ______________________________
Simon
Post #399934 10th Aug 2016 11:53am
ebajema
I vaguely remember that BMW had a problem with the waterpump impeller losing its vanes over times, so turning fine but not moving much water. So I suggest to have a look at that as well but I'm not sure if the same waterpump made its way into the L322. MY 2010 5.0 SC Galway green and sand interior!!
Post #399940 10th Aug 2016 1:21pm
fisha
I would replace the rad, water pump , expansion tank ( genuine part only is a must for this) and mod the thermostat to the lower temp. All fair easy stuff but worthwhile to keep on top of the coolant. V8 or else ...
Post #400002 10th Aug 2016 7:16pm
p38arover
Australia
And check that the tank has a 140kPa cap, not 200. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #400053 10th Aug 2016 10:46pm
johnboyairey
I've had a few coolant problems, but mainly due to leaks. If you are not losing significant coolant, then half the battle is won.
The rad comes out easy enough, the water pump, is a bit tricky. You have two metal pipes on the back, they go to the rear y piece that feeds the rear of the engine, sometimes, it hard to get the pipes back into the rear holes, without dislodging the o rings, -(they are at front and back,) so take great caution, to somehow, not let the pipes come out of the rear, like don't let them come forward by 5 MM. At the same time! as you are pulling water pump off. Lube them on reassembly with some vasalene. Even easIer is to change the thermostat..just four bolts. (Soak them first though. ) but there is a modified thermostat, for about £50 from a guy in Germany, and it cuts the running temps down to 85 degrees. Easy job.
I think you could have a stuck thermostat, or the pump is shot. Like the impeller has come loose. Either way, you could do no wrong, ( as a temporary) to change thermostat, maybe then, remove rad, check for debris, who knows what has been put in. They are about £150 I think. Don't bother with a secondhand one, as so many people have problems with rads leaking. The pump is about £75 too. use the mini bleed valve on the tank, to help fill it and run it up, then tighten it.
One other tip. If you remove a rad hose, they go brittle, so, slide the clip, and don't twist it, they don't twist. You have to wobble it gently. Again a bit of vasalene, as each hose has an o ring. But slide the clip back on and then seat the hose, so you hear and feel the clip reseat, otherwise, they pop off if you slide (after) them and they don't seat.
£2400 -
nice!
Post #400055 10th Aug 2016 11:10pm
UK Marine
Hi Guys and thank you all for your excellent advice, it's all been taken onboard.
I took the radiator off today and noticed this when I looked in the top hose,
Then I looked in the radiator and saw this,
Soooo I then looked in the thermostat....
Then I turned the radiator upside down and, well this lot came out. I don't think I have to tell you what it looks or feels like but I washed my hands pretty quickly after touching it I can tell you..
So I think I got to the bottom of my blocked radiator, although flushing won't achieve much as it has a few high pressure steam leaks around the seams,
So if you don't mind opinions as to what that sludge is, I think it's some kind of stop leak but it could be mixing of incompatible antifreezes. Anyway new radiator and thermostat ordered even though I don't think that the thermostat is at fault now, but might as well seeing that it's off ______________________________
Simon
Post #400125 11th Aug 2016 2:44pm
johnboyairey
That stuff is known as 'Harry Monk's sperminating high-protein cream'
You might want to try and flush through your engine, before it dries, and the goop sticks. Maybe try and run a hose pipe through the rad hoses. If you can clear the rad a bit, maybe, refit it, and fill and run it a few times, as you don't really want to circulate any more man-gravy through the new rad. Don't worry about gasket leaks for now. Just de-goop it. There is quite a bit of water, between the heads, and in the block.
I think you might be quite lucky. I bet the rad has been super-blocked, and the rest is localising the heat build up.
Post #400130 11th Aug 2016 3:16pm
UK Marine
Classic Laughing
I gave the engine a good flushing with the hose just to be sure.
I have to say in all of my years of spannering I've never seen that stuff anywhere near an engine, well except maybe when I got too close to that Ferrari 458 ..........
Regards to all ______________________________
Simon
Post #400135 11th Aug 2016 3:32pm
johnboyairey
Looks like it was put in to seal the radiator. So, maybe that explains its presence.
Usually it's some k seal or bars leak. Or wonder weld. And that is sort of brown. Or red.
People used to talk about, 'putting an egg' in. But that would be even uglier. And would stink.
As you know, there's only one way to fix something, and that's to fix it, not bodge it. But it seems your gain in the long run.
I wonder, in Co Antrim, are these cars high taxed? I (being an Englishman) seem to remember hearing stories of high taxed l322 rangies, with no rear seats!
Post #400142 11th Aug 2016 3:59pm
UK Marine
County Antrim, I've no idea. I live County Durham up by Newcastle upon Tyne, ha way the lads and all that.......... ______________________________
Simon
Post #400170 11th Aug 2016 7:04pm
Weegie
I think you are thinking of the Irish Republic where, as I understand it, vehicle tax rates are very high.
On the other hand County Antrim, being in Northern Ireland, is part of the United Kingdom with the same rates of tax as the rest of the UK. John
GAP iiD BT
Post #400173 11th Aug 2016 7:22pm
