![]() | Home > Maintenance & Mods (L322) > Location of air suspension filter |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I have RAVE disk......
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
is it not under the spare wheel rich.. ... - .- -.
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
This topic should help - http://www.fullfatrr.com/forum/topic2884.html |
Thanks for the link. But the same question is asked at the end of the thread...Where's the actual filter located.
The reason I asked this question is I'm getting the warning messages "AIR SUSP INACTIVE", ABS other warning lights are on dash.
Air Susp and ABS error mesages are often battery related, an old battery cant keep up the voltage to the ECU's whilst cranking, so they fire up fine, you start the car fine, but the voltage drops off so they power down, but they the car is running so everything gets confused. Cant help you with EAS filter though, although do you mean the dryer unit? ![]() |
Yes the dryer.
This is the one in the spare wheel well
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
I think thats the pressure relief valve in that pic, if its failing (blowing air) just bypass it, later cars dont have it. The dryer is within the air supply unit (turtle shell) with the compressor and other components. I think land rover only sells the complete air supply unit so unless you find out otherwise its not worth stripping it down. I got a new comprosser for £270 somewhere.
I have a new battery, fitting it tomorrow.
Well new battery fitted....switched on and started car, turned steering wheel lock to lock....and still have warning lights and HDC INACTIVE and AIR SUSP etc
What's your charge voltage? |
Unsure (volt meter playing up)
