Home > Maintenance & Mods (L322) > New (to me) L322, oxidized door handles |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
The simplest way is to put door handle covers on. I did this, it means you can colour code too if you want to.
9th Aug 2016 4:52pm |
Kinch Member Since: 08 Aug 2016 Location: Idaho Posts: 45 |
Sweet! Thanks, but what's the backwards, cross between a cursive L and lower f looking thing next to the number 59 lol? Seriously, though, although I wouldn't have the satisfaction of doing the job myself, this would ultimately look better and take less time. I will look for them from a US website. Thank you. |
9th Aug 2016 5:13pm |
Do you think it looks best to match your paint, or go with black? |
9th Aug 2016 5:14pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8672 |
Go with colour coded if you can aS the later cars had coded handles. Failing that grey.
9th Aug 2016 5:19pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
There's a good how to on this in the wiki, by pete, haylands on here.
9th Aug 2016 6:37pm |
Yeah just read it. Probably give it a try. I can't find the door handles on Amazon or ebay (the US versions) in anything but chrome. But they are very cheap. I might be able to get the chrome ones. Scuff them up with some light sand paper, and then paint them before putting them on. Could be a easy and cheap solution.
9th Aug 2016 6:57pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8348 |
Um... what's the point of buying covers and painting them when you might as well paint what you have...!!!
10th Aug 2016 1:53pm |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Depending on the year of the XJ the Range Rover is a polar opposite. I came from a 1995 wrangler YJ. |
10th Aug 2016 2:05pm |
I was thinking I could save some time, and save the risk of screwing up, and breaking through my tape, and marring the finish of my vehicle. That would bug me forever.
10th Aug 2016 2:17pm |
You can repaint or wrap the interior silver but you have to remove every last bit of the silver down to bare plastic as nothing sticks to it...
10th Aug 2016 5:08pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
It's easiest to spray paint the handles in place. Tape well around them and add paper/plastic to mask the doors. Then a little sanding with fine grit paper, a thin layer of primer, three-four thin layers of colour, then a layer of clear coat. This is done in a few hours. Let it harden for a couple of weeks before you buff and polish it. ----------
10th Aug 2016 8:07pm |
I will try it this weekend. May or may not provide the results lol. |
10th Aug 2016 8:10pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
As per le25dse's quote. Did mine a few weeks ago & looks good,
10th Aug 2016 8:45pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
As an electronics tech, the use of the term "colour coded" really jars. Colour codes mean the different colours mean different values, e.g., resistor colour codes, black = 0, brown = 1, red = 2, etc.
10th Aug 2016 10:41pm |
