Home > Technical (L322) > Interior LED difficulties
Kinch
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
I am attempting to replace the interior lights on my 2006 L322 with LED's. I am having extreme difficulty removing the bulb from the round, light that is close to your knee on both front seats. Can't remember what the manual calls it. The manual says to gently pry out with a flat head screwdriver. I can tell that I am dangerously close to breaking the bezel, or marring the finish on the dashboard. Any help out there? Thank you.
Post #399845 9th Aug 2016 8:47pm
Kinch
Upper footwell lights is what they're called. Having the hardest time removing them. Tried again tonight. Anyone know the trick?
Post #399880 10th Aug 2016 4:49am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
You can take the trim off the side and remove from there.
Post #399883 10th Aug 2016 6:29am
Kinch
If by trim you mean the round part that surrounds the lens, that's the part I can't get out. I've pried on it and while it will move a bit, there is not much of a lip to grab onto and the screw driver slips off. It's a matter of time before I damage something.
Post #399917 10th Aug 2016 11:48am
gregdav
No, the black side panel, as you open the door, you can get a scraper or some flat tool and prise it off.
you should then be able to either push the fitting out or twist the bulb holder. Thumbs Up
Post #399918 10th Aug 2016 11:58am
Kinch
Okay thank you. Will give that a try after work. Just the whole big piece of black plastic? Just pops off? I'll give it a whirl.
Post #399920 10th Aug 2016 12:09pm
gregdav
Yes whole big black plastic piece. Depending on the size of your hands, it can be a little restricted in there.
Best of luck. Thumbs Up
Post #399998 10th Aug 2016 7:54pm
Kinch
Thanks!
Post #400014 10th Aug 2016 8:52pm
Kinch
FYI, I got it done. Pried off the panel, and was able to reach in, grab the wire, and pull the entire bulb and fitting out, changed the bulb, and shoved it back in the orifice. Thanks for the help.
Post #400136 11th Aug 2016 4:34pm
