![]() | Home > Technical (L322) > Interior LED difficulties |
Kinch Member Since: 08 Aug 2016 Location: Idaho Posts: 45 ![]() ![]() ![]() |
Upper footwell lights is what they're called. Having the hardest time removing them. Tried again tonight. Anyone know the trick? |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
You can take the trim off the side and remove from there.
If by trim you mean the round part that surrounds the lens, that's the part I can't get out. I've pried on it and while it will move a bit, there is not much of a lip to grab onto and the screw driver slips off. It's a matter of time before I damage something. |
No, the black side panel, as you open the door, you can get a scraper or some flat tool and prise it off.
Okay thank you. Will give that a try after work. Just the whole big piece of black plastic? Just pops off? I'll give it a whirl. |
Yes whole big black plastic piece. Depending on the size of your hands, it can be a little restricted in there.
Thanks! |
FYI, I got it done. Pried off the panel, and was able to reach in, grab the wire, and pull the entire bulb and fitting out, changed the bulb, and shoved it back in the orifice. Thanks for the help. |
