Home > Technical (L322) > Door mirrors don't dip when reversing.....
Rob99
The owners handbook says my door mirrors should dip when reverse is selected. They've never done this since I had the car a few weeks ago and I thought it was just a setting.
Now I have my IID tool I have checked and the CCF says the dipping mirrors should be enabled.
Any thoughts? Am I doing something wrong?
Rob 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #399864 9th Aug 2016 10:49pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Did you move the button next to the folding mirrors button ? It turns on and off the function 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #399865 9th Aug 2016 10:54pm
Rob99
There are two buttons and they don't have an effect on the mirrors when reversing. Sad
One is a slider to select right or left mirror for adjustment, the other is just a push button which manually folds the mirrors in/out. Confused 2021 D350 Fifty Edition - Carpathian Grey
Post #399866 9th Aug 2016 11:00pm
dolph34
If you put the mirror selector switch to the left , when you reverse the mirror will dip 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #399870 9th Aug 2016 11:14pm
Zeppfish
It can be turned on and off in the vehicle settings menu on the tft dash! Use the right hand control on the steering wheel to navigate the menu 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #399881 10th Aug 2016 5:10am
Earlier cars were controlled by the sliding selector switch for the mirror adjuster - and only the passenger side dipped
On a 2012, both mirrors dip - as above, the mirror dip function is controlled from the steering wheel button going into the settings menu in between the speedo and rev counter.
Post #399882 10th Aug 2016 6:07am
Rob99
Thanks. Thumbs Up
Will try it again when I get home from work tonight. 2021 D350 Fifty Edition - Carpathian Grey
Post #399889 10th Aug 2016 7:28am
defo in the dash settings Rob. Thumbs Up ... - .- -.
Post #399890 10th Aug 2016 7:31am
Rob99
All sorted and working a treat......cheers Thumbs Up Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
Post #399975 10th Aug 2016 5:43pm
