Home > General > protect & secure your ffrr |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
9th Aug 2016 4:51pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
A lad at work has one and they look strong and easy to work. I had a similar but much older type and it was a fiddly fag to use so ended up in the boot most of the time.
9th Aug 2016 5:28pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
I borrowed one of these to see how it would do. I decided not to bother as it was heavy and clunky and I thought there was a chance of damaging the interior of the car with it. I showed it to my girlfriend for her BMW as there was a lot of news at the time about them being stolen with electronic devices - she was put off by the size/weight/operation too and wouldn't have used it. Only Range Rovers since 1988 |
9th Aug 2016 6:17pm |
Hey Giantlandyman Thanks for coming back to me on this one - appreciated This is worth knowing, my colleague had a Ferrari - it had a tracker fitted. One night a few years ago he parked it at home - got up in the morning and no car. Apparently the tracker unit was found by the local plod a few hundred yards from his door on the grass. We talked about this and came up with the view that depending on the type of car - there's only so many places to fit the tracker. I am not saying Tracker is useless, but what I am saying is the fact that when you have one fitted, you are not allowed to see where it is - do they fit them in the same places depending on model car - if so surely the thief's know where to look - that would explain how they got his Ferrari away ? The whole point of this - is has anyone got one - do they fit the FFRR nicely - I hear you point of it being heavy with your GF - but thank god is made like the FFRR - Solid ??? PS - I Think Tracker is good - but do the thief's know where to look and disarm ?????? anyway thanks for coming back Fella Best wishes . |
9th Aug 2016 6:47pm |
9th Aug 2016 6:55pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
I agree with that; there are only so many places a Tracker can be fitted plus when it comes to fitting, it is a set price so they are hardly going to, for example, dismantle the dash and hide it in the depths. Therefor, there are set places they normally go on a FFRR. I am going to try and find somewhere that stocks those locks and give them a try. I did give the manufacturer a call a while back and they reckoned that if they are given the diameter and depth of the wheel, they should have one to fit although they recommend putting a cover (supplied) over the steering wheel first. Good luck and whoever buys first can make the report for the other. |
9th Aug 2016 10:20pm |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
could always get 3 trackers fitted, that way when they find one and rip it out they'll assume that's it and be on their way haha. Dan
15th Dec 2016 10:31am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7948 |
IMHO this kind of thing is potentially worth it for an airport car park with something as popular/common as a FFRR - it's enough to make the would be thief move along to the next available one.
15th Dec 2016 12:22pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 899 |
If steering wheel locks are a visual deterrent and the weight and awkwardness of their use puts people off......why doesn't someone make a plastic one?
15th Dec 2016 1:16pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
I know it's significantly more money but if I had a late model one I would go with something like this......
15th Dec 2016 1:52pm |
A nice and cost effective solution from BlackBox Solutions is available which hides the keyless module from the CAN. It can be hidden wherever you want as long as you connect it to the CANBUS wiring so pretty much anywhere in the car.
15th Dec 2016 2:00pm |
And a very good price... great find... Pete
15th Dec 2016 2:13pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
We have now gone full circle...physical device to electronic alarm to physical device... |
15th Dec 2016 3:38pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Back in the late 80s and early 90s cars used to get nicked for fun so a few of my cars I fitted a 'kill switch'.My 2.8 capri I cut into the fuel pump supply and hid the switch under the seat buried into the carpet,you could have the keys and it wasn't going anywhere.I know the Full fat is far more technical but can this simple cut out be done without causing any harm to the electrics ? |
15th Dec 2016 7:02pm |
