Home > Technical (L322) > 2004, 3.0 TD6 Vogue, oil leak underneath front |
anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121 |
Good evening everybody, some help required in identifying an oil leak underneath engine bay.
3rd Aug 2016 4:57pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8330 |
Looks like the diff, difficult to see where it's leaking from though, if it's the seam then I think it's a diff out job to sort it... not cheap if you're paying for labour...
3rd Aug 2016 5:21pm |
Thanks Pete. The leak is only a dribble at present, but I have concerns it may get worse. |
3rd Aug 2016 11:07pm |
Yep, they don't usually get better, that's for sure... Pete
3rd Aug 2016 11:15pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
Looks to be running down from the right hand driveshaft output, the interface where it goes through the sump, so most likely a seal issue unless it's engine oil coming from above. Engine oil won't be golden colour though, especially on a diesel, unless it's literally just been changed.
4th Aug 2016 12:18am |
Thanks Weejock , deffo not engine oil, the oil leaking is a golden syrup in colour and smells like diff oil. is the changing of the seals an expensive job at the local indy? |
4th Aug 2016 8:08am |
