![]() | Home > Technical (L322) > 2004, 3.0 TD6 Vogue, oil leak underneath front |
anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121 ![]() ![]() ![]() |
Good evening everybody, some help required in identifying an oil leak underneath engine bay.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
Looks like the diff, difficult to see where it's leaking from though, if it's the seam then I think it's a diff out job to sort it... not cheap if you're paying for labour...
Thanks Pete. The leak is only a dribble at present, but I have concerns it may get worse. |
Yep, they don't usually get better, that's for sure... |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Looks to be running down from the right hand driveshaft output, the interface where it goes through the sump, so most likely a seal issue unless it's engine oil coming from above. Engine oil won't be golden colour though, especially on a diesel, unless it's literally just been changed.
Thanks Weejock |
