Home > Maintenance & Mods (L322) > Rear motor headache!!! |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
bump :/ |
28th Jul 2016 2:34pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Your park switch internally of the wiper mechanism is not working correctly.
28th Jul 2016 9:44pm |
Dare I ask what th park switch looks like? I spent some time trying to work out the correct blade position as I didn't mark it - also should it tuck under the left or right? It catches my camera on the way past not sure if that makes a difference |
29th Jul 2016 7:31am |
I haven't stripped down the rear wiper to the internals so I couldn't tell you what the park switch looks like exactly but it'll be a small changeover micro switch which operates when the wiper reaches the park position and turns it off. It could be a physical switch or it might be a sensor, either way it'll have wires going to it, for a switch it'll be 3 wires.
29th Jul 2016 8:04am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8255 |
The wiper parks up under the passenger side (RHD) it shouldn't get anywhere near the drivers side.... Pete
29th Jul 2016 9:43am |
Just checking thats where it sometimes stops - and where the end of the swipe is - halyard do you ave any idea where this switch is before i rip it open again? |
29th Jul 2016 9:44am |
Sorry, mine had a brand new one on it when I bought it so that's one thing I haven't had to pieces, as Weejock says it is usually a microswitch or sometimes a brass track on the back of the large toothed wheel inside that runs over little tangs within the body of the unit, it is imperative that if you took parts out, especially toothed wheels that they went back in exactly the same place, one tooth out and it won't work properly...
29th Jul 2016 9:54am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
I recall my brother in law had a similar issue. When we stripped the black box where the wiper shaft gives into, there was a spring type mechanism which had dislodged.
29th Jul 2016 10:20am |
