![]() | Home > Maintenance & Mods (L322) > Where is this oil leak from in the valley pan? Video |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
Is this my mysterious oil leak? Coming from the valley pan?
I did wonder about those orange seals, it needs to be sorted as I have drip all over the sump etc. Maybe I should do rocker gaskets too while I have the inlet off. What do you do about the valley pan gasket then? Can you actually buy a gasket? 2004 RR 4.4 V8 Autobiography |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if you have weeping rocker cover gaskets, then start there! that is by far an easier job. you change the inner and outer rocker gaskets. fairly easy, you might want to change your plugs at same time, and investigate the plugwells filled up with oil. (normal!) you should soak up as much oil with dry rag, and then unscrew each plug, with a decent reaching plug socket. taking care to hold the extension straight. -if plug wells are dry, spray in some Plusgas to penetrate the threads as they bake themselves in. with all that done, clean up your covers area, and monitor etc. as this stopped my leaks, running down side of engine, and onto steering rack etc.
Well thank you for all that info, a very big help |
yes, if you have a water leak, then use this thread i have posted on to see the american guy do the job on a BMW he uses the RTV method, i would now recommend using a new cover, with built in new (harder) bead applied already. http://www.fullfatrr.com/forum/topic33408-45.html
