Home > In Car Electronics (L322) > Update RR main screen software?
tiddles1991
United Kingdom 2004 Range Rover Vogue Td6 Buckingham Blue
Is it possible to update the actual software without replacing the whole screen to make it look more modern?
I think It looks like a horrible Windows 98 type screen at the minute, or am I just being picky?
Post #397802 26th Jul 2016 4:39pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
You would need to do the MK4 sat nav upgrade in order to install the latest available firmware.
Check out my website www.myrangerover.co.uk for more details on this upgrade
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #397810 26th Jul 2016 6:27pm
tiddles1991
Thanks Matt, is it worth it in your opinion? I've seen the DVD unit on eBay for around £200 and brand new android units with camera etc for around £280-£300.
Post #397814 26th Jul 2016 6:39pm
mattstevenson2005
It is most defernaltly worth it, I think it's the single best upgrade you can do on the early range rovers. It's a simple plug and play swap and a quick upgrade with my firmware disc to install all the features. The android head units are want for a better work Censored ! They look cheap and awful and they don't even fit in the dash correctly as they are designed to fit in BMWs with the curved dash where as ours are flat, so of them you have to butcher all the factory wiring to get it to work. The OEM MK4 system even though it's getting on a bit now is more than enough functionality. You can add AUX in, Bluetooth, reversing camera etc... with the factory systems you just have to search round to find the how too's Thumbs Up
Hope you make the right choice!
Matt Current
Post #397902 27th Jul 2016 11:06am
