Home > In Car Electronics (L322) > Mk 4 Sat Nav problem
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Much of the time the sat nav works fine, However every so often it will lock up, and then reboot.
Just recently it has started to do this multiple times until the unit is frozen out completely and a default alternative display comes up, I can still access all the other functions through the screen once this alternative display comes up.
A period with the car stopped will always cure this.
Is this a known failure mode? Is there a known fix?
Many thanks
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2 and now FFRR.
Yes I'm a masochist....
Post #397103 22nd Jul 2016 10:24am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Not had this myself, but have you checked the disc is clean. If so, its probably the disc motor on the way out.
There is a guy in Birmingham who advertises on eBay (navman I think) who fixes these things - best drop him a note - if you search for Mk4 DVD repair on eBay you'll find him - sorted out a problem I had with mine very quickly Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #397797 26th Jul 2016 4:02pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
This is caused by the TMC feature, if the TMC system receives too many messages at the same time is causes the until to continually reboot. Eject the disc then reboot the until and it should come back up normally the. Disable the TMC system in GPS Navigation and the issue won't happen anymore
I am working on a further upgrade to the v32 firmware that will fix this issue
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #397812 26th Jul 2016 6:29pm
p38arover
Australia
I'm using Matt's software and don't have TMC enabled (I don't know if it's used in Oz) and I've had no problems. (Much nicer having LR Range Rover on the screen, too, rather than BMW.) Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #397855 26th Jul 2016 10:43pm
mike whiskey
I'll give that a try and see what happens.
It does only seem to happen once the unit has been on a while, so I guess it could be the messages building up. I was wondering if it was overheating or something like that.
A shame because I quite like the TMC, Be good to know when there is a fix available.
Thanks
Post #397889 27th Jul 2016 10:05am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
can any of these be used in 2007 units? thanks _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #397893 27th Jul 2016 10:37am
nope Neutral ... - .- -.
Post #397897 27th Jul 2016 10:47am
mattstevenson2005
I'm hoping to have the Range Rover firmware upgrade sorted to solve this issue over the next 4 weeks. I will announce it on this forum when it's ready.
Matt Current
Post #397909 27th Jul 2016 11:17am
mike whiskey
Great news, thanks
Post #397918 27th Jul 2016 12:18pm
