Home > Technical (L322) > Is it worth fitting extra fans? |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
I have noticed during the recent hot weather that the temperature gauge has been quite quick to get to working temp (no surprise) but I was wondering if it was worth fitting additional electric fans to the front of the radiator?
24th Jul 2016 10:21am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8202 |
Designed by Land Rover to tow a massive trailer across the Sahara desert so you don't need anything extra...ever....
24th Jul 2016 10:29am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
There is an additional electric fan used for the air con. If the engine coolant temperature increases too much then the electric fan will also step up a speed. It's why the viscous fan can often be ditched in cooler climates with no issues.
24th Jul 2016 12:03pm |
As well as the points above, it's important to maintain a good cooling system rather than fiddle with it by adding fans (Not even sure where one would cram them?)
24th Jul 2016 12:09pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
See here also
24th Jul 2016 3:26pm |
So it would seem that there is at one job that I wont have to add to the list then.... QUID FACIUM TIBI
25th Jul 2016 8:34pm |
