Home > Technical (L322) > Is it worth fitting extra fans?
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
I have noticed during the recent hot weather that the temperature gauge has been quite quick to get to working temp (no surprise) but I was wondering if it was worth fitting additional electric fans to the front of the radiator?
The viscous fan seems a bit small to be able to handle the loads when towing etc, any recommendations? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #397410 24th Jul 2016 10:21am
Designed by Land Rover to tow a massive trailer across the Sahara desert so you don't need anything extra...ever....
Lot's of folk running without a viscous on the diesel... they run nice and cool.... Thumbs Up Pete
Post #397412 24th Jul 2016 10:29am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
There is an additional electric fan used for the air con. If the engine coolant temperature increases too much then the electric fan will also step up a speed. It's why the viscous fan can often be ditched in cooler climates with no issues.
Transmission cooling is the usual issue when towing but as Haylands says, with a properly working system it shouldn't be a problem.
Post #397419 24th Jul 2016 12:03pm
dan_uk_1984
As well as the points above, it's important to maintain a good cooling system rather than fiddle with it by adding fans (Not even sure where one would cram them?)
Yes the OAT Coolant can go 5+ years without a change, but for the sake of a few quid, why risk it? I change the coolant immediately when I buy a car and yearly from then.
Post #397423 24th Jul 2016 12:09pm
See here also Wink
http://www.fullfatrr.com/forum/topic38664.html .
Post #397445 24th Jul 2016 3:26pm
Spelunker
So it would seem that there is at one job that I wont have to add to the list then.... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #397648 25th Jul 2016 8:34pm
